Oculus Developer Forums
All OR applications give me a blue window
Report any bugs or technical issues that you encounter related to the the SDK or the Developer Center. The Oculus team collects information from this forum.
Postby jthebomb97 » Sat Apr 20, 2013 2:36 pm
I've been having a problem actually launching applications for the Oculus Rift, specifically any demo/scene in Unity. I suspect I'm having a problem with Unity specifically.
Whenever I launch a program (the beach demo, for example) I select my quality/screen resolution as usual, but then it launches in a window/full screen and just fades to blue (shown in the picture). I haven't even plugged in the rift for this yet, this is just the result of me starting the programs on my computer. Any troubleshooting help would be appreciated, thanks! :)
You do not have the required permissions to view the files attached to this post.
jthebomb97
Re: All OR applications give me a blue window
Postby drash » Sun Apr 21, 2013 11:50 pm
If this is happening for your own Unity projects, make sure you are building to the x86 target, not the x64 one. I believe Oculus is already aware of this issue. Hope this addresses your blue screens!
Titans of Space - current version is 1.37 (released Oct 14th), available for Win/Mac/Linux.
Translations are available at the official website.
Blog & other VR projects: DrashVR.com.
User avatar
drash
Postby cybereality » Mon Apr 22, 2013 11:08 am
Yes. This happens when you build for x64. We've actually fixed the issue, it will go out with the next release.
The work-around for now is to build for x86.
Oculus VR - Community Manager
User avatar
cybereality
Team Oculus Team Oculus
Postby rburlette » Thu Apr 25, 2013 11:22 am
I had this exact issue until I installed .NET updates, as well as other Windows Updates. I figured there was some C# .NET feature that Unity was using that needed to be updated on my machine.
rburlette
Postby cybereality » Thu Apr 25, 2013 1:32 pm
@rburlette: Interesting. That's good to know.
User avatar
cybereality
Postby lgruen » Sun May 12, 2013 3:32 am
I had the same issue with the demo download (ovr_unity_0.2.1_demo.zip), but the binary version in the SDK (ovr_sdk_0.2.1_src.zip) worked just fine. Maybe the demo download needs to be updated as well? I had all Windows 7 update installed and installing the newest .NET framework didn't help.
lgruen
Postby cybereality » Mon May 13, 2013 5:24 pm
The SDK download uses C++, so its very different from the Unity demo (even though they use the same scene). This blue-screen thing seems like a Unity specific issue. I thought it had been fixed, but I can let the team know it's still happening.
User avatar
cybereality
Postby Boff » Sat May 25, 2013 9:53 am
I'm also getting the issue with a blue window/screen when running Win_OculusUnityDemoScene. No problem with the SDK version (OculusWorldDemo) as has already been posted.
Strangely, the Unity demo runs fine on my laptop (Win7 x64, AMD GPU) and my office laptop (Win7 x64, Intel integrated GPU).
But on my desktop (Win7 x64, Nvidia GPU) I get the blue window.
It's a fairly fresh install of Windows but all updates are applied. Installed .NET Framework 4.5, VC++ Redist 2005 to 2012 but still no difference.
Hope this info helps anyway.
Cheers
Boff
Boff
Postby JamesMcCrae » Tue May 28, 2013 11:13 am
I have a specific fix that worked for me. Fresh install of Windows 7, graphics drivers (nVidia) installed. Tuscany Rift demos show a "blue rectangle" - and all other Unity-based demos showing a similar uniformly coloured rectangle (probably the selected colour to clear the colour buffer with in each case, in other demos this has been grey or black).
Installing this specific package caused all stereo Unity demos to work immediately after:
Microsoft Visual C++ 2010 x86 Redistributable.
(Make sure you grab the x86 one)
Knowing this would have saved me some time/pain :) (I don't think it's in the SDK doc for setup, at least 0.1.5 anyway. Clearly you wouldn't need the redistributable package if you already have visual studio 2010 and are compiling/running C++ apps on the machine, but you do for deployment on other machines. Anyway, figuring it out was non-trivial for me since the Unity apps did run and there was no complaint about missing DLL, etc., which would clearly indicate the problem)
Anyway hope this helps someone!
User avatar
JamesMcCrae
Postby Boff » Wed May 29, 2013 3:50 am
Thanks for the reply James, I was just about to write a follow-up post to say I'd sorted the problem when I saw your reply!
After comparing the 3 machines again I saw that the only things missing were MS VC++2005 (x86) & 2010 (x86).
I'd only installed the x64 versions when I did the initial install of the Frameworks.
After installing both, Win_OculusUnityDemoScene worked fine and the Tuscany Unity Integration package ran fine without reporting missing DLL's in the console.
Panic over! Still, it would have been nice to see it mentioned somewhere in the prerequisites.
Boff
Postby cybereality » Wed May 29, 2013 10:53 am
Glad to see this fix is working. I will ask about updating the docs to reflect this.
User avatar
cybereality
Postby maxiebabe » Thu Jun 27, 2013 11:01 am
JamesMcCrae wrote:Installing this specific package caused all stereo Unity demos to work immediately after:
So received my Rift and was really enjoying it except for demo's crashing out within a few minutes, Seems my Geforce was fubar (perfect timing) and nothing to do with the Rift!
SO today in preparation of a new GFX arriving I did a nice fresh install of Win7 64. After putting on all the drivers I booted up the Rift and....Blue screen on every demo. After panicking for quite a while I decided to check out the forums and saw this post. Installed the Microsoft Visual C++ 2010 x86 Redistributable and....nothing.....still that horrible blue screen every time....wiggled cables.....used different USB ports.....changed from HDMI to DVI.....NOTHING.
Till I remembered that I was in a rush when I installed the OS and told Windows to NOT update. Ten minutes later windows now fully up to date and....IT WORKS!!!!!
Hope this helps anyone else who goes through a fresh install of Windows and turns off auto update.
maxiebabe
Postby cybereality » Thu Jun 27, 2013 11:05 am
Thanks for posting this maxiebabe.
Also, there is a issue with Avast that causes all Unity demos to crash. Not sure if you had Avast installed, but that could have been the problem.
User avatar
cybereality
Postby maxiebabe » Thu Jun 27, 2013 11:40 am
cybereality wrote:Also, there is a issue with Avast that causes all Unity demos to crash. Not sure if you had Avast installed, but that could have been the problem.
Was purely the update issue I am afraid as after a fresh install with nothing else added, I booted up the Rift. Again, hopefully this information will stop other people freaking out when it does not work in this way.
maxiebabe
Return to Reporting Issues
Who is online
Users browsing this forum: vrdaveb and 4 guests
