Oculus Developer Forums
Titans of Space - A Guided Tour (UPDATED to v1.37 - Oct 14)
A place to talk about Oculus-ready games and demos that can be used with the Rift development kit.
Postby drash » Fri Jun 07, 2013 7:58 pm
I noticed some recent comments about wishing for an astro-educational VR experience, or wishing to be able to fly through the Solar System, etc. It is nice to see comments like that, because right now I am releasing my first space-themed VR project called "Titans of Space".
Overview:
Titans of Space is a short guided tour of a few planets and stars, the point of which is to give the player a sense of scale of just how big these planets and stars are compared to each other.
It's not meant to be realistic, but more on the surreal holographic side. Everything you see is shrunk down to 1 millionth of their actual size, which means you will see Earth as a 12.7-meter-wide holographic ball, rather than the giant 12756km-wide ball of rock that it is.
Although the tour is on rails, you can proceed through it at your own pace. The controls are very simple as there are merely five things you can do during the tour:
  1. Look around
  2. Zoom in on things
  3. Read the tour guide panel in front of you
  4. Rotate a planet or moon (when the option is available)
  5. Proceed to next tour stop whenever you're ready
Titans of Space supports several forms of input: Oculus Rift, keyboard, mouse, Xbox 360 gamepad, and Razer/Sixense Hydra.
Once the tour is underway you don't actually need any of that (aside from the Rift) unless you wanted to zoom in on something or fiddle with options.
There is a lot of information presented before the tour starts but you don't need to remember any of it.
All of that information about controls and options (and more) are accessible at any time during the tour, just hit Escape (or gamepad X button):
For those without a Rift, I've also included a "non-stereoscopic" option. However, please keep in mind that this VR experience is intended to be experienced in VR the first (and only?) time you play through it, so if you have a Rift on the way I would simply recommend you wait to get your Rift first before trying it out. :)
It takes a minimum of 14 minutes to blast through the whole tour without taking your time and without taking any breaks, so plan accordingly.
As mentioned earlier, all sizes are to scale (1:1000000), but distances between objects are not to scale in any way.
I tried to be astronomically correct for everything else so if anyone sees any glaring errors (within reason), let me know (at drash@crunchywood.com).
Controls:
Basic controls:
  • Show Options:
    ---- {Esc} / {Gamepad X}
  • Proceed to next tour stop:
    ---- {Enter} / {Return} / {Click Right Mouse Button} / {Gamepad A}
  • Zoom:
    ---- Hold {Spacebar} / {Left Ctrl} / {Left Mouse Button} / {Gamepad Left Trigger} / {Gamepad Right Trigger}
  • Quit:
    ---- {Q}
Advanced controls (new as of v1.37):
  • Rotate Planet/Moon:
    ---- {Left arrow} & {Right arrow} / {Gamepad D-Pad Left} & {Gamepad D-Pad Right}
  • Slow down or speed up:
    ---- {Down arrow} & {Up arrow} / {Gamepad D-Pad Down} & {Gamepad D-Pad Up}
  • Screenshot:
    ---- {F12}
Additional options (and all listed under in-game Options):
  • Toggle Vsync: {V}
  • Toggle Framerate Indicator in right eye: {F}
  • Adjust FOV: {[} & {]}
  • Toggle Anti-aliasing: {A}
  • Toggle Motion Intensity Level: {M} ('Low' is standard, 'High' has a slightly more interesting flight path)
  • Toggle Labels: {L}
  • Toggle Tour Guide Information Panel: {T}
  • Toggle Looping Demo Mode: {D}
  • Toggle Non-stop Mode: {N}
  • Toggle Soundtrack: {S}
Experimental options:
  • Toggle Dynamic IPD: {I} (This causes some planets/moons to feel larger when you get very close to them)
Setup Notes:
  1. Crank up the sound or use headphones! Sound effects and music are an integral part of this experience.
  2. , and makes the text far more readable. Titans of Space will automatically strip away unnecessary eye-candy in order to reach a decent frame rate (if it can), and with all the extras turned off it will still look pretty good in the Rift as long as you're downscaling from 1920x1080.
  3. Do not use Vsync / "wait for vertical refresh" / "vertical blank". There are two major reasons for this:
    a. Titans of Space wants to know your true frame rate in order to adjust eye candy, at least for the first few seconds after the tour starts.
    b. Vsync is proven to double the latency in Titans of Space, and it tends to be very noticeable in this particular experience. But, after the framerate has settled, feel free to experiment to see how vsync feels for you.
    If you have fiddled with your vsync settings in the control panel for your graphics card, please go back and make sure you don't have vsync forced on:
    * For ATI/AMD users, you'll want to look in the "Catalyst Pro Control Panel" -> "3D Application Settings" -> "Wait For Vertical Refresh" setting and set it to "Off, unless application specifies" (this is the default).
    * For Nvidia users, you'll want to look in the "Nvidia Control Panel" -> "Manage 3D Settings" -> "Use the 3D application setting" (this is the default).
  4. If you have a Razer Hydra and wish to make use of it for positional body tracking (for leaning in your seat), you'll have to figure out a way to affix a Hydra controller to your upper torso. After you have done so, lean back in your chair and hit the Start button on that Hydra controller (while Titans of Space is running) to start tracking your body position. (Note that you can still use any Hydra controller to zoom/advance to the next tour stop.) If you find your body position drifting, you can reset it again using Start button (when leaning back in your chair), or just stop using it by docking it back on the base station. Ensure your base station is oriented such that the cables are coming the back of the base station (more specifically, the cables should come out in the direction of your "forward" direction)!
  5. Performance Requirements: DirectX9.0-capable graphics card (only tested on DX10+ cards, however). Titans of Space maintains 120-200 FPS (with maximum eye candy and anti-aliasing ON) on an NVIDIA Geforce GTX680, 30 FPS (with all eye candy shut off and no anti-aliasing) on a 6-year-old ATI Mobility Radeon HD 3670.
  6. Translations / Alternate English Text: Starting in v1.3, nearly all text is localizable into other languages or even just an alternate version of the standard English text. This includes planet/moon/star names, tour guide text, menu screens, etc. Spanish, German, Swedish, Italian, Czech, French, Danish, Brazilian Portuguese, and Dutch translations are available on the website. There is a text file named "tourguideV1.37.txt" inside the _Data folder which holds all of the text values used by Titans of Space, and it is simply a matter of changing those to whatever text you like. (For MacOSX, use Show Package Contents on the app file, open the Contents folder, and find this text file is *next to* the Data folder, not in it.) Anyone should feel free to volunteer their own translation by emailing it to me (along with a description of the translation and how you want to be credited), after which I will post it on the website for others to use.
    • Please note that at this time, only Latin and Latin-Supplement unicode characters are supported and a graphic of these supported characters can be viewed here.
    • There is not a lot of room for text, so be sure to check your changes inside of Titans of Space. To speed up this process, use the TAB key to quickly skip through the different tour stops. (Or use shift-TAB for even faster flights)
    • If all text shows up blank inside Titans of Space, that means you need to convert the text file to UTF-8. NotePad++ is a free text editor that can do this via Encoding -> Convert to UTF-8.
    • If you change text #124 (v1.31+), you may also want to change #125 through #132 as those are the coordinates of the "play button icon" and "Oculus Rift icon".
      • (x,y) coordinates of Play Button Icon in the main Menu: (#125, #126)
      • (x,y) coordinates of Oculus Rift Icon in the main Menu: (#127, #128)
      • (x,y) coordinates of Play Button Icon in the in-tour options Menu: (#129, #130)
      • (x,y) coordinates of Oculus Rift Icon in the in-tour options Menu: (#131, #132)
    • Between v1.33 and v1.34, the following changes have been made to translations and may need (re-)translation
      • Changed: #51, #60, #61, #73, #82
      • Added: #169, #170, #171, #172
  7. Custom Soundtracks: Starting in v1.3, you can place one or two of your own songs into the "CustomMusic" folder inside the _Data folder. For MacOSX, use Show Package Contents on the app file, and the CustomMusic folder is inside the Contents folder.
    • If you want to replace the music heard while touring the Solar System, place a song named "solarsystem.XXX" into the CustomMusic folder, where XXX is any file extension corresponding to one of the following formats: Ogg, WAV, XM, IT, MOD, or S3M.
    • To replace the music heard in the "Large Stars" segment, place a song named "largestars.XXX" into the CustomMusic folder.
    • You can replace one or replace both.
    • To stop using custom music, remove these songs from the CustomMusic folder.
    • These songs will be looped.
  8. Yaw Drift Correction: If you have not already calibrated the Rift's magnetometer using the OculusConfigUtil, it's important to follow the instructions at the beginning to calibrate the magnetometer for yaw drift correction. Use deliberate head movements. If you're unable to follow those instructions or it doesn't seem to be working (don't break your neck), hit ESC to skip it and Titans of Space will attempt to automatically calibrate it for you as you look around.
    There is now visual feedback as to whether yaw drift correction is working. On the left side of the tour guide panel readout, there are 3 lit indicators:
    • If yaw drift correction has been successfully calibrated, the top indicator will be green.
    • If drift correction is not yet calibrated, it will be red.
    • After being calibrated, when yaw correction is actually in progress, this top indicator will briefly be yellow.
    • The second indicator from the top will be gray until the first time yaw correction occurs and then it will stay green to let you know yaw correction has actually occurred at some point.
Known Issues:
  1. If you run Titans of Space in Windows windowed 1080p mode you will probably see either see a black screen or an upside-down image. To work around this, either start it in full screen, or start it in windowed and then switch to full screen using Alt+Enter.
  2. If you run Titans of Space on MacOSX in fullscreen on "Oculus Rift - Fast PC" quality level, you may see different images for each eye (black screen, missing cockpit etc). The workaround here is to run it in Windowed mode instead, or try "Oculus Rift - Slow PC" fullscreen and let it automatically increase the quality as appropriate.
  3. If you experience drift, use the B key (or gamepad B button) to reset your forward direction. Drift calibration now works very well so you may not ever need to do this.
  4. Visible guide paths no longer work properly.
Changelogs:
Changelog for v1.35 -> v1.37:
  1. Feature: Almost everything has received a facelift of some kind (some of it is pretty subtle, though). However, the animated surface of stars has been removed as it was unrealistic and very GPU-heavy.
  2. Feature: Most adjustments to settings are now saved between sessions. Hitting the F1 key will restore all settings to their defaults.
  3. Feature: Some planets and moons can be rotated at will using the left/right arrow keys (or left/right d-pad buttons on a gamepad controller). A yellow icon on the right will show up when this option is available.
  4. Feature: Travel between tour stops can be slowed down at will and even stopped completely. Use the up/down arrow keys (or up/down d-pad buttons on a gamepad controller). A blue line below the information panel indicates the current setting.
  5. Performance: Performs better on newer computers, performs worse on older computers. Framerate is more than doubled for a GTX 680, but framerate drops to 30 FPS on an old ATI Mobility Radeon HD 3670.
  6. Other minor adjustments and bugfixes.
Changelog for v1.34 -> v1.35:
  1. Feature: Updated to use Oculus SDK 0.2.4. You may now calibrate your magnetometer using the new Oculus Config Util (available from Oculus as of 8/16/2013), and Titans of Space will use that instead of asking you to calibrate every time it starts.
  2. Feature: Take screenshots by hitting the F12 key (useful for fullscreen modes where native printscreen tends to fail). Screenshots will appear in the app's Data folder as "screenshot###.png" where ### is a random string of letters and numbers.
  3. Other minor adjustments and bugfixes.
Changelog for v1.33 -> v1.34:
  1. Feature: To restart the tour at any time, hit the R key.
  2. Feature: Instead of random stars in the night sky, actual stars are now used. How many constellations can you pick out?
  3. Feature: Added a "Nonstop Mode", where the distracting controls and facts panel in front of you will disappear and there will be no delay at each tour stop. The player will still stop briefly at each destination, but continue on to the next immediately. This is toggled on/off using the N key.
  4. Feature: Either Hydra controller may now be used for positional body tracking. Just hit the Start button on the one you want to use.
  5. Feature: Updated to use SDK 0.2.3. This means more robust drift calibration and automatic usage of your IPD if you have configured an Oculus profile. Note: The profile that has "set as default" checked is the one that will be used.
  6. Feature: To toggle showing the tour guide facts panel on and off, use the T key (or gamepad right shoulder / hydra button 3 or 4). This could be useful if you wanted to test yourself on the information like peeking at flash cards.
  7. Feature: There are now two Oculus Rift quality levels, "Slow PC" and "Fast PC". Both will give you the exact same experience, but Slow PC will start off with no eye candy enabled and work its way up, and Fast PC will start with all eye candy enabled and work its way down. This eliminates much of the slowdown right when a tour starts for the first time on a slower computer.
  8. Feature: 4x MSAA anti-aliasing can now be toggled using the A key. The screen will blank temporarily when you toggle this. 4x MSAA results in a serious hit to performance for not a lot of benefit (IMO), but the option is there if you want it.
  9. Feature: To sort-of-quickly fly to the next tour stop, use the TAB key. Use Shift-TAB to do the old 1-second quick-fly feature available in previous versions.
  10. Vsync seems to feel great for me now, not sure why! But, it will still be off by default so that appropriate quality level can be determined. Feel free to experiment with vsync after the frame rate stabilizes in the beginning.
  11. A small number of translation file changes have been made. If you use anything other than English, please be prepared for some minor inaccuracies until the changes are (re-)translated. More info in Setup Notes above.
  12. Bugfix: Turning off demo mode during the return trip to Earth would screw things up afterwards.
  13. Bugfix: Turning on demo mode right after starting the tour did nothing.
  14. Other minor adjustments and bugfixes.
Changelog for v1.3 -> v1.33:
  1. MacOSX support. Only tested on a 4-year-old Mac Mini running Lion -- it worked but ran poorly (20-45 fps, all eye candy shut off). If it runs great or poorly for you, I would be interested to know what kind of Mac you have.
  2. Bugfix: Replacing only the music for large stars segment is now working properly.
  3. Small changes to make Titans of Space completely translatable.
  4. Experimental Feature: IPD trickery mode. Use the I key to toggle. Best used in "high" motion intensity mode. When this is on, flying close to planets or moons will cause them to appear larger than you thought they were. This feature is undocumented inside Titans of Space, but you will know it is off if you see a red light on the lower left of the indicator light area. Once it is on, it varies from black to light blue depending on how close you are to a planet or moon.
  5. Added indicator light (middle left of indicator light panel) to show what quality level Titans of Space is running at. As the quality is reduced to improve frame rate, the color of this indicator will go from greens to yellows to reds to black.
Changelog for v1.2 -> v1.3:
  1. Bugfix: Yaw drift correction is greatly improved, with visible feedback during the tour. (See Setup Notes for more info.)
  2. Feature: The cockpit seat's headrest has been removed for improved visibility behind you.
  3. Feature: A new looping demo mode with auto-continue at each stop after small delay (use D key to toggle, demo loops around Solar System only).
  4. Feature: Supports translations / alternate text for nearly all text. (See Setup Notes for info on how to create/use a translation or alternate text.)
  5. Feature: A motion intensity setting has been including for those craving more a motion-intense experience. By default this is "low", and "low" mode is the same as the flight path in v1.2 and earlier. (use M key to toggle)
  6. Feature: Custom soundtracks. Can replace the songs for the Solar System and Large Stars segments individually. Custom songs will be looped. Formats supported: Ogg, WAV, XM, IT, MOD, S3M. (See Setup Notes for info on how to use your own music.)
  7. Feature: Can toggle soundtrack completely off, but sound effects will remain. (use S key to toggle. Note after being off, toggling back on does not take effect immediately)
Changelog for v1.1 -> v1.2:
  1. Bugfix: On slower/older machines, one of the large stars stuck around when it shouldn't have.
  2. Feature: Use L key to toggle planet/star labels (but you have to toggle it twice before it works, I'll fix that next time).
  3. Cockpit (and your suited body) is now 20% larger.
  4. Adjusted flight path round Europa & Io.
  5. Made it a little bit more clear that if the user skips the drift calibration at the beginning, the forward direction may need to be frequently reset during the tour.
Tip Jar:
Titans of Space is free to use (in a non-commercial setting), but if you happen to like it a lot you can thank me (and help me recoup the cost of a Unity Pro license) with a PayPal donation:
Download links:
(The download is roughly 225MB in size. Apologies to those with slower internet connections!)
Windows:
Titans of Space v1.37 (Windows) from Oculus Share
Titans of Space v1.37 (Windows) from DropBox (Sometimes suspended due to high traffic)
MacOSX: (Tested on Lion only)
Titans of Space v1.37 (MacOSX) from Oculus Share
Titans of Space v1.37 (MacOSX) from DropBox (Sometimes suspended due to high traffic)
Linux: (Untested)
Titans of Space v1.37 (Linux) from ADrive
And, due to the graphical facelift in v1.37, it performs a little worse on older computers, so v1.35 is still available below:
Windows:
Titans of Space v1.35 (Windows) from DropBox
Titans of Space v1.35 (MacOSX) from DropBox
All of the above information and download links are also available at http://www.titansofspace.net.
I hope someone enjoys playing this! :)
Titans of Space - current version is 1.37 (released Oct 14th), available for Win/Mac/Linux.
Translations are available at the official website.
Blog & other VR projects: DrashVR.com.
User avatar
drash
Re: Titans of Space - A Guided Tour
Postby adam » Fri Jun 07, 2013 9:04 pm
That was a great experience, I really enjoyed the stars after the sun!
Perhaps provide some hint to get people to stay until the end - I imagine some folks may stop when they get to the outer planets.
Cheers, Adam.
adam
Postby danworld » Fri Jun 07, 2013 10:11 pm
Holy crap....holy crap....
How can I describe how amazing this is? I've tried out pretty much every demo available so far and been blown away several times. But I have never sat there just continually mouthing out my astonishment like this.
When you showed the larger stars, I was almost afraid, like I was looking in to the face of God. When you said that the largest one is expected to explode in the next 100,000 years, I was actually apprehensive you were going to show that right then.
Congratulations for making the absolute best solar system learning experience EVER. And one of the best learning experiences ever. And one of the best experiences, period.
VR, man.
User avatar
danworld
Postby mrgreen72 » Fri Jun 07, 2013 10:15 pm
1920x1080 looks 100x better than 1280x800.
This is a big no-no in my opinion. It does help with the aliasing quite a bit, but the downsampling job you leave to the Rift's screen adds to the latency and could contribute to more motion sickness.
That being said, this looks fantastic! I barely scratched the surface because it's late and I've had my dose of VR for tonight but what I've seen was simply amazing. Definitely something I'll show to the whole family. Great work!
User avatar
mrgreen72
Postby HappyHimitsu » Fri Jun 07, 2013 10:30 pm
Wouldn't that be almost entirely dependent on the oomph behind your computing power?
I can run most recent pc games on 1920x1080 in stereoscopic mode at 60fps, so I don't think I should have much to worry about as far as added latency due to down-sampling. Or am I missing something in my logic?
~A stone rolls not off the path of it's own accord~ -JT
~Let go or be dragged~ -Zen
'Be Wary of Geeks bearing Gifts....' -trojan/win32.war
User avatar
HappyHimitsu
Postby Tagera » Fri Jun 07, 2013 11:07 pm
Now this is a fun demo and exploration trip rolled into one. Great use of the mapping that has been done to the planets, moons and Ceres. I especially loved Mars and had to sit and watch it for a few minutes while it turned. Especially as Olympus Mons came around. When it comes to mountain climbing, that would be the one to do it on. Adding in a few other stars was a nice touch also. It's good that you did keep the scale down. Putting it at a realistic scale I think would probably either scare a few people or at most make them very sick. I could probably handle it pretty well without issues, but you'd definitely have to back the viewpoint out from a much further distance.
Tagera
Postby mrgreen72 » Sat Jun 08, 2013 12:04 am
Yes. You are missing that the screen does the downsampling, not your computer. The screen accepts the 1080p signal from the computer and scales it down to 1280x800. Downsampling could be done by the computer and that wouldn't be a problem as long as it could hold a 60 fps.
In fact, UDK demos do exactly that when you crank up the ScreenPercentage parameter.
User avatar
mrgreen72
Postby SteelClawz » Sat Jun 08, 2013 12:05 am
That was the MoSt Amazing simulation i have seen yet! Better than a trip to the planetarium, and the planetary simulation at the aquarium of the pacific in long beach. what a professional demo
1080p worked awesome...
i got a fast computer!!
SteelClawz
Postby Duckaz » Sat Jun 08, 2013 12:34 am
Wow, just wow.
User avatar
Duckaz
Postby Zonetripper » Sat Jun 08, 2013 1:16 am
Great! This is the first I will show people from now on.
Zonetripper
Postby JOHIsaac » Sat Jun 08, 2013 2:47 am
Thank you drash for sharing this!
This was so awesome. When Saturn showed up behind Jupiter I giggle like a little child. And the Sense of scale is great. When you fly out to have Canis Majoris in it's full scale I watched down to my left and saw the sun and our planets, that was sooo cool.
Thanks again, this is now on my favorite list!
JOHIsaac
Postby dead4sure » Sat Jun 08, 2013 3:24 am
That was an absolutely awesome experience! It played well on my machine at a res of 1920x1200 and felt amazing! This is the kind of thing that should be in schools, kids (and adults of course) would get so much out of this!
My only feedback would be similar to what someone said earlier. Some kind of progress indicator would be cool so that people don't quit too early! The stars at the end were a huge surprise and it really added a wow factor!
10/10 good effort! :D
User avatar
dead4sure
Postby wavefunction84 » Sat Jun 08, 2013 5:38 am
Yeah, that was almost the most incredible demo I've seen yet.
Being able to see things like that with actual scale... wow. What a great teaching device this is! Being able to actually see the sheer magnitude of objects in our universe really puts things in perspective (including how small us puny humans really are).
To be honest, I found the stars to be somewhat horrifying. Just the thought of knowing that they exist and how massive they are daunts my primitive chimpanzee brain. Seeing VY Canis Majoris made me shrink into my chair in fear and awe. Damn universe, you scary!
wavefunction84
Postby drash » Sat Jun 08, 2013 5:42 am
I'm really humbled by the comments here. I couldn't have asked for a better response! :shock: I'm so glad someone enjoyed this.
To address the concern about players possibly quitting prematurely, I've updated the first post with new download links to V1.1 which has a new progress indicator on the left side of the tour guide panel. Very good suggestion, so thanks for that! :)
User avatar
drash
Postby Valez » Sat Jun 08, 2013 6:22 am
This is my new favorite Rift experience. :)
Three little things:
Removing the headrest of the chair would make looking behind you better.
I would like to choose my own music for repeated play-throughs.
Speech would be great.
Valez
Postby jojon » Sat Jun 08, 2013 6:33 am
:o
Now please excuse me, while I spend the rest of my life rambling around the surface of Frogstar world B, making "blblblbl"-noises. :7
Beautiful execution, in every way.
"Attempt no landing there", heh. :D
EDIT: Any alternative ways of tipping? ...or should one just throw one's trust into the intangible world of bitcoin? :7
jojon
Postby jayoh » Sat Jun 08, 2013 7:14 am
brilliant, stunning, awe-inspiring.
my only request: free roam mode while the planets are on their own orbit!
i'm building STV.RE
jayoh
Postby Qix » Sat Jun 08, 2013 7:26 am
I don't have my rift yet but I loved it. Great work!! Thanks for posting it. :) Speech with the ability to toggle on and off would be a great addition but as it stands it's still a wonderful experience.
Qix
Postby klausfly » Sat Jun 08, 2013 8:17 am
What a great trip! Many thanks! :-)
Definitely on my rift-top-list.
klausfly
Postby mrgreen72 » Sat Jun 08, 2013 9:10 am
SteelClawz wrote:1080p worked awesome...
/facepalm
User avatar
mrgreen72
Next
Return to Oculus-ready Games and Demos
Who is online
Users browsing this forum: ElectricGrey, Google [Bot], sparrow and 8 guests
